Activity › Forums › Adobe Premiere Pro › Premiere CC 2018. Playback 4K is Choppy (lag) GTX1080
  • Premiere CC 2018. Playback 4K is Choppy (lag) GTX1080
    Posted by Arve Hansen on August 31, 2018 at 6:57 am
    I use 4K footage from DJI Mavic Air and Sony A7III in mp4.
    Have newest update for Premiere CC 2018. 1-2 weeks ago.
    Hardware:Win10 64 bit. I7-8700K With 32GB memory. GPU GTX770 2GB.
    In timeline when hit Space bar I have now problem. But if I drag cursor With the mouse back and forth The Picture freeze sometimes get black for 1-2 Seconds after I drop the cursor.
    Yesterday I bought a New GPU. MSI Gaming X Geforce GTX 1080 8GB and hope this will help alot. But I can’t see any different. Still choppy/lag With 1-2 secunds. I use also Full, 1/2, 1/4, 1/8. But still choppy.
    Tried to put 4k footage at C drive. This is a Samsung 970 250GB M.2 SSD.
    (And I use CUDA).
    What can be the problem?
    Gopro Hero 4 Black
    Daniel Waldron replied 8 years ago 5 Members · 11 Replies
  • 11 Replies
  • Tero Ahlfors
    August 31, 2018 at 7:04 am
    [Arve Hansen] “What can be the problem?”
    [Arve Hansen] “I use 4K footage from DJI Mavic Air and Sony A7III in mp4.”
    I’d recommend transcoding these to DNxHR.
  • Arve Hansen
    August 31, 2018 at 7:11 am
    Thanks. Transcoding these to DNxHR. Never heard about this. Hope you can explain this for me. Or if you have a link.
    Do I still use Adobe or?
    Gopro Hero 4 Black
  • Tero Ahlfors
    August 31, 2018 at 8:13 am
    Bring the files to Adobe Media Encoder and render them out with the same resolution and framerate but in DNxHR.
  • Arve Hansen
    August 31, 2018 at 10:00 am
    Thanks alot. What are different/best to transcoding these to DNxHR or Proxy?
  • Arve Hansen
    August 31, 2018 at 3:06 pm
    One more. Try convert my 1.4GB (Pal 25) mp4 file to DNxHR HQ UDH 25. The file got 10.3GB. 10 times more, but smooth. Så why can a 10 times big file og so smooth?
  • Tero Ahlfors
    August 31, 2018 at 3:47 pm
    If you have compressed footage your computer is working hard to decode it. Especially if it’s 4K. DNxHD, Cineform and Prores take more space but are easier to decode and are visually lossless.
  • Shane Ross
    August 31, 2018 at 5:26 pm
    [Arve Hansen] “What are different/best to transcoding these to DNxHR or Proxy?”
    DO you want to work in high resolution? Or do the offline (low res) to cut, and then go back to the masters when done? If you convert the 4K MP4 files (recommended) to DNxHR, you’ll see them increase in file size by a factor of 5 or 6…they will get BIG. Why? Because the data rate is higher, making them easier to edit…less compressed. Compressed MP4 4K takes a LOT of horsepower to decode on the fly. So if you do convert to 4K DNxHR, make sure you have a lot of hard drive space, and FAST hard drives…or playback will lag.
    Or, you can do the offline proxy workflow…something you can google for the process. Highlight the clips in your project, make proxies (this will take time, so over night is good)…and then you can edit with those proxies, and editing will be easier, but you can relink back to the originals with the click of a button.
    Shane
    Little Frog Post
  • Chris Wright
    September 1, 2018 at 12:07 pm
    the proxies can be smaller or multiples of the resolution.
  • Daniel Waldron
    September 4, 2018 at 1:18 pm
    4K H264 files take a lot to decode and DJI’s codec is notoriously slow in Premiere. Like Tero mentioned, transcoding is a good option. Or you can create proxies (DNxHD is a good option) so you can edit smoothly, then with a click of a button have the high-res original media back online.
  • Arve Hansen
    September 4, 2018 at 3:39 pm
    Can I color correcting, Color grade and denoise on the Proxy and this will take effect when exporting?
