Activity Forums Adobe Premiere Pro Premiere Can’t Match Sequence Settings??
  • Premiere Can’t Match Sequence Settings??
    Posted by Mark Mallett on September 13, 2011 at 7:14 pm
    I am using Premiere to apply Mercalli stabilizer and then export back to FCPX. However, when I choose Match Sequence Settings for export option, the video Premiere outputs is black. Full length black.
    Is there a secret Adobe is hiding from me, or does someone have an explanation as to why? In FCP 7, you can simply export a Quicktime movie, which is essentially your sequence settings. Not so, it seems, in Premiere, unless this is a bug…
    Kevin Monahan replied 15 years ago 2 Members · 1 Reply
