Activity › Forums › Adobe Premiere Pro › Premiere can’t import mov rendered in AE?
  • Premiere can’t import mov rendered in AE?
    Posted by Moe Sizzlac on November 15, 2007 at 8:40 pm
    Hi fellas,
    i’m on workin on a project, and i worked on some footage in After Effects7, in a .mov format (codec: PHOTO JPEG), and now i can’t import it in Premiere CS3… Please Help!!! This is an emergency…
    Peace
    Jon Barrie replied 18 years, 10 months ago 2 Members · 1 Reply
  • Jon Barrie
    November 15, 2007 at 11:59 pm
    The wrapper of a mov shouldn’t cause any issues in the import of PPro. The codec shouldn’t have issues either. I just did a test from AE 7 into PProCS3 and it worked fine. What’s the error your getting? If you need to use it ASAP and rendering it is an issue you can directly import the AE7 comps like any other piece of footage.
    Import> *.aep file> choose the comp/s you want to work with.
    Otherwise re-render a test with only a small section of the comp, by adjusting the end point of the work area with the n key to snap to the CTI (time indicator).
    – Jon
