Activity Forums Adobe Premiere Pro Premiere can't import a quicktime file
  • Premiere can't import a quicktime file
    Posted by Malcolm Desoto on August 22, 2024 at 8:27 pm
    Woke up to Premiere randomly deciding to not import quicktime files correctly. Haven’t changed a single setting or update. The quicktime file was rendered out of After Effects.
    When I import the file, it looks like it’s playing back at half opacity with weird lines running through the image.
    Importing an .mp4 works totally fine. Any ideas what random thing Premiere is messing up?
    Running Premiere 23.5, After Effects 23.5
    https://vimeo.com/manage/videos/1001744047/5722536103
    Malcolm Desoto replied 2 years ago 2 Members · 3 Replies
  • Bob Gale
    August 22, 2024 at 9:54 pm
    This may not have to do with anything, but maybe first try changing the quality on your program window from 1/4 to FULL. It looked like the lines only were present when you played the video and they went away when you stopped.
  • Malcolm Desoto
    August 22, 2024 at 10:09 pm
    Good guess, but that is not the case. File presents artifacting regardless of resolution.
  • Malcolm Desoto
    August 23, 2024 at 12:54 am
    Hey guys, updated everything to 24.6 and that resolved the issue.
