Activity Forums Adobe Premiere Pro Premiere CAN’T handle h264 MOV?
  • Premiere CAN’T handle h264 MOV?
    Posted by Michele Poggi on May 8, 2017 at 1:34 pm
    I had this problem with my old Workstation, and it’s the same with a new one.
    …So, this has to be a Software Issue.
    I have recorder (with OBS) some .mov video files with h264 encoding.
    Premiere couldn’t import them (it took audio only) without Quicktime installed, and it’s ok.
    But then, when I import them, it CAN’T handle them.
    In no way.
    It doesn’t do playback at all, you can’t work with them. It shows 1-2frames every 3-5 seconds.
    It’s as like it can’t read them properly.
    And I don’t even know how to explain it more in-depth, it seems quite a simple fact to describe: It’s impossibile to work with them…
    And I honestly don’t know what to do, except encode them with handbrake, since even AME will show infinite amount of hours to handle them.
    “Freelance Post-Producer”
    Editor Video
    Graphic Designer
    Digital Compositor
    Mail: snm.poggi@gmail.com
    Mobile: +39 3349129191
    Skype: sabakunomaiku
    Ole Kristiansen replied 9 years, 4 months ago 5 Members · 7 Replies
  • 7 Replies
  • Daniel Waldron
    May 8, 2017 at 2:02 pm
    H.264 is more suited for final delivery than for editing, but Premiere can certainly handle it. What are your computer specs?
  • Jeff Pulera
    May 8, 2017 at 2:09 pm
    Just helped someone on another forum that was having issues with OBS files in Premiere. By default, the OBS recordings were using VARIABLE Frame Rate, which Premiere doesn’t like. Use the free HandBrake app to convert the recording to CONSTANT Frame Rate, then edit the new file in Premiere.
    Jeff Pulera
    Safe Harbor Computers
  • Chris Wright
    May 8, 2017 at 3:38 pm
    I thought I read an adobe post on OBS where he forced recording in constant frame rate without needing to transcode.
  • Michele Poggi
    May 9, 2017 at 8:39 am
    Indeed…! Thank you very much.
    I’m remuxing the files now. OBS actually create horrible desynchs while recording in mp4, so I’ll change my workflow.
  • Michele Poggi
    May 9, 2017 at 8:40 am
    They should handle it!
    CPU: AMD Ryzen 1700X
    MOBO: PRIME X370-PRO
    RAM: 2x Corsair Vengeance 16GB 2400MHz
    GPU: Nvidia GeForce GTX 1080
  • Michele Poggi
    May 9, 2017 at 8:41 am
    I’ll check it out!
    Though I can’t find the option in OBS Studio for now, I’ll search throughfully.
  • Ole Kristiansen
    May 9, 2017 at 10:18 am
    Try rename the MP4 extension to M4V
