Activity Forums Adobe Premiere Pro Premiere Bug with Blackmagic Decklink 4k mini monitor
  • Premiere Bug with Blackmagic Decklink 4k mini monitor
    Posted by Greg Janza on April 17, 2018 at 7:17 pm
    I’m running the latest version of Blackmagic’s Desktop Video Setup with Premiere 12.0 and sending my video output through HDMI to a Lilliput professional monitor. And my GPU is a 970GTX.
    If I create a 24p timeline in Premiere, when I start playing back my timeline my output monitor switches to 24 hz. Likewise, if I create a 29.97 timeline, before playing back, my monitor switches to 30 hz. This might all be normal but the problem is that Premiere takes 2-4 secs to reset the refresh rate in order to play back each timeline.
    So this impacts the editing of a project with mixed frame rate media quite dramatically because I’m continuously waiting for the monitor to post an image when switching between different frame rate footage.
    At first I thought it might be my HDMI connection. I made sure I had a 2.0a HDMI cable. I then output the Premiere signal to multiple monitors to rule out the monitor itself. The problem presents itself on a variety of monitors.
    Lastly, I downloaded Resolve 15 and attempted to re-create this problem in Resolve but couldn’t. Resolve works perfectly. There’s no delay switching between frame rates. All output to the monitor is instantaneous.
    So then it sure appears to be Premiere bug. Has anyone else who uses a Blackmagic Decklink 4k mini monitor with Premiere encountered this bug?
    Windows 10 Pro
    i7-5820k CPU
    Nvidia GeForce GTX 970
    Adobe CC 2018
    Renders/cache: Samsung SSD 950 Pro x2 in Raid 0
    Media: Samsung SSD 960 PRO PCIe NVMe M.2 2280
    Media: OWC Thunderbay 4 x 2 Raid 0 mirrored with FreeFileSync
    Greg Janza replied 4 years, 7 months ago 2 Members · 2 Replies
  • Grant Van zutphen
    April 26, 2021 at 2:02 pm
    This is a very delayed response to your original post, but if Adobe hasn’t addressed this issue since 2018, I believe you could resolve it using the HDMI Instant Lock feature on the Blackmagic Design Mini Converter SDI to HDMI 6G – detailed here in this video:
    https://youtu.be/L4qDh-qRBG8?t=782
  • Greg Janza
    January 4, 2022 at 5:04 pm
    Thanks for the info!
