Activity Forums Boris FX Premiere / BCC Tracker / Can´t clear cache
  • Premiere / BCC Tracker / Can´t clear cache
    Posted by Sabri Liefert on May 11, 2012 at 5:35 pm
    Hello,
    i want to reset/clear a tracker.
    There is a screen showing “To clear the cache, slightly
    change an unused parameter in the effect.”
    But i changed parameters and pressed reset several times. The message doesn´t disapear.
    Premiere CS5.5 / BCC Cont. 8.0.2
    (btw: this is driving me crazy)
    Jeremy Ellis replied 14 years, 4 months ago 2 Members · 1 Reply
  • Jeremy Ellis
    May 14, 2012 at 8:45 pm
    Hello,
    You are correct that this should not be happening. What effect are you using when you see this? Are you moving the playhead to the first frame when trying to clear the cache? Please feel free to email me directly at jeremy@borisfx.com
    Thank You
    Jeremy
    Boris Support
