Activity › Forums › Adobe Premiere Pro › premiere audio plugins automation
  • premiere audio plugins automation
    Posted by Emmanuel Hungrecker on October 7, 2020 at 3:07 pm
    Hi
    when setting for exemple an eq in the audio track mixer, playing back audio and moving a parameter (most of the time) writes keyframes and automate that setting. Which is annoying because i want to monitor the effect of a plug in to determine how much of each parameter i wanna set.
    so either it writes automation or it comes back at the original setting when stopping the playback
    how do we change play/write options for plug ins automation?
    in protools for exemple we have a pref window where we select what to record during playback, I couldn’t find something similar, nor a workaround. One time it goes back to the value before playback, the next i got to go to the track keyframe for that parameter then erase the pass… realy slow!
    Does anyone know a workaround? Staying in premiere i mean.
    best
    e
    Emmanuel Hungrecker replied 5 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
