Activity Forums Adobe Premiere Pro Premiere Audio Ghosting in Sequences
  • Premiere Audio Ghosting in Sequences
    Posted by Daniel Flesher on June 24, 2014 at 6:25 pm
    Friends,
    I just updated Premiere CC to 8.0.0. When I change between sequences and begin scrubbing with the cursor, the audio from the previously viewed sequence plays. However, when I playback in real time, the correct audio plays.
    For example, I’ve created a selects sequence with several takes. I take a look at them then switch over to my actual cut. When I scrub through my actual cut, I hear the audio from my selects sequence. Regular playback is fine, though.
    Has anyone else experienced this? Is there a workaround? Any help is greatly appreciated.
    We are running on a server and here are my specs:
    OSX 10.9.3
    2×2.66 GHz 6-Core Intel Xeon
    34 GB 1333 MHz DDR3
    NVIDIA Quadro 4000 2048 MB
    Daniel Flesher replied 12 years, 1 month ago 1 Member · 1 Reply
  • Daniel Flesher
    August 12, 2014 at 6:29 pm
    I know other editors experiencing this issue. I also haven’t gotten a response on the Adobe Forums. Has anyone found what is causing this problem?
