Activity Forums Adobe Premiere Pro premiere and crappy renders
  • premiere and crappy renders
    Posted by Justin Young on May 5, 2010 at 1:35 am
    I have a project in premiere and am now ready to export a quicktime file. I have high res assets, but when I export, and the media encoder comes up, I get really fuzzy low res crappy renders.
    What am I doing wrong? My settings are as follows:
    NTSC DV widescreen
    29.97 FPS
    Quality 100
    Here’s some images to demonstrate what I’m talking about. The first is taken when I’ve deleted all work area files:
    https://dl.dropbox.com/u/52435/1.png
    The next is what I get once I render the .mov: (see how crappy that looks?)
    https://dl.dropbox.com/u/52435/2.png
    Slobodan Milivojevic replied 16 years, 4 months ago 3 Members · 2 Replies
  • Jon Barrie
    May 5, 2010 at 2:33 am
    DV is very poor at maintaining color edges in reds, I wouldn’t trust the way it looks on Quicktime either. QT will always show DV files in a soft low quality. If you have QTPro you can manually change the setting (Ctl/Cmd+J) for video to highest, but then you need to save it like that to keep it just for that video.
    If your video is for web – export to H.264 at square pixel ratio.
    If your video is for DVD – export it to MPEG-2 DVD at Highest Preset Settings.
    – Jon Barrie
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
    http://www.suiteskills.com
  • Slobodan Milivojevic
    May 6, 2010 at 6:21 pm
    Make sure that if you export progressive footage make custom progressive sequence (default Premiere sequences are interlaced) for your format specs and resolution.
    After that, export in animation, h264 or photojpeg format for best quicktime quality….
    I hope this helps….
