Activity Forums Adobe After Effects Premiere and After Effects crash
  • Premiere and After Effects crash
    Posted by Malcolm Desoto on April 20, 2013 at 7:14 pm
    This is kind of both an after effects question and a Premiere question but here it goes…
    System:
    Windows 7 Pro
    3.2GHz hexcore i7
    64 GB RAM
    GeForce GTX 570
    After Effects and Premiere 5.5
    I’ve been having trouble rendering in both After Effects and Premiere. In Premiere, the progress bar will just freeze and I have to force quit the application. In After Effects, I’ll get a message that say it had to quit the render and the file may be corrupt. I checked all of the files and they’re all fine. Just a lot of 1080 DSLR footage and some simple graphics.
    I did my rough edit in premiere and the color grade/vfx in after effects. I think the problem might be the dynamic link feature which I’m using. It seems to slow everything down.
    I have a 120GB SSD set as the disk cache. Could that be an issue? I’m also working from an external drive connected vie esata.
    Sometimes, if I just restart the computer, everything will run smoother.
    Any ideas on how to smooth out this work flow a little more?
    Tom Daigon replied 13 years, 3 months ago 2 Members · 3 Replies
  • Tom Daigon
    April 20, 2013 at 8:04 pm
    I do a lot of dynamic linking between PrP and AE on a PC (HPZ820). I can tell you that in CS6 it is MUCH more stable.
    Malcolm, try this workflow and see if it helps.
    1. Cut in PrP
    2. Select clip on TL and send to AE as DL
    3. Work on comp in AE.Save.
    4. Check in PrP. Render in PrP if needed to view.
    5. Refine back in AE. When satisfied, I export as DNxHD making sure I check “Project Link” in the AE export queue dialog box.
    6. I import into PrP and replace the DL version of the clip on the timeline with the DNxHD movie.
    7. If I need to change thing, I select clip and right click. Then select “Edit Original”. Boom, the AE project opens and I make revisions.
    Also it might be a good idea to delete all your Media Cache and Preview files in their respective folders, just to clear out old junk that might be screwing things up. Then open PrP and try this flow out.
    Tom Daigon
    PrP / After Effects Editor
    HP Z820 Dual 2687
    64GB ram
    Dulce DQg2 16TB raid
    http://www.hdshotsandcuts.com
  • Malcolm Desoto
    May 28, 2013 at 2:07 am
    Sorry for the very late reply. I’ve been up to my elbows in deadlines. This post was very helpful and has been working very well! This seems to be a great workaround. Can’t wait to upgrade to CS6 and enjoy a smoother DL process.
  • Tom Daigon
    May 28, 2013 at 3:23 am
    No problem Malcolm. Glad to help.
    Tom Daigon
    HP Z820 Dual 2687
    64GB ram
    https://www.youtube.com/playlist?list=PLfV20RTBQmUxgDXDkRHDC_j2f62vBUF_n&feature=edit_ok
