Activity › Forums › Adobe Premiere Pro › Premiere + AE video = problem
  • Premiere + AE video = problem
    Posted by Avlsound on July 12, 2007 at 3:30 pm
    Hi guys,
    I am editing something in Premiere
    but I did the titles in AE.
    The problem is that after I export
    the stuff from AE and bring it into the
    Premiere timeline the quality of the AE
    video suddenly goes down and becomes pixelated.
    It is fine even when I preview the footage
    in the Premiere monitor, but as soon as it is
    inserted into the timeline it looks bad.
    I use Premiere Pro 2, AE 7.
    The titles were exported at the highest quality
    based on the lossless AE template.
    Anybody knows what might be the problem?
    Thanks for you help in advance!
    AVL
    Vince Becquiot replied 19 years, 2 months ago 4 Members · 6 Replies
  • Vince Becquiot
    July 12, 2007 at 5:10 pm
    Let’s first look at your preview. Is this in an external monitor or in the Premiere preview window ?
    The Premiere preview window will never look as good as the export, since, even at full quality, it will be rasterized. So, either do a small uncompressed export, or take a look at it in an external monitor for a true quality assessment.
    The second thing has to do with DV. If you ARE working in DV, bringing a title over footage will force a new compression to DV of that entire clip.
    This change may not be drastic, but it will be noticeable.
    Now, unless you are exporting to DVCAM / MiniDV, that doesn’t matter, since it will not reflect the final export; it’s only compressed for preview.
    Hope that helps,
    Vince
  • Steven L. gotz
    If Dynamic link is not an option, export your titles using the Quicktime Animation codec and remember to use Millions of Colors + (the + sign is important).
    Remember to not use any white above 235,235,235 and no blacks below 16,16,16.
    Steven
    https://www.stevengotz.com
  • Bart Straman
    July 12, 2007 at 8:19 pm
    ehm, you can just open your AEfile in Premiere…
    dynamic link ofers you things , like when you edit it in AE it wil adjust at the sametime in Premiere if both are on, very cool stuff.
    Bart
  • Bart Straman
    July 12, 2007 at 8:27 pm
    oowhjea, another thing. “when you brought it to your timeline”, or at it to your composition. mayby the composition settings in AE where you’ve made your title and in Premiere are different. give that a look too.
  • Avlsound
    July 12, 2007 at 11:24 pm
    Thanks guys for your help!
    The composition settings were the same in both applications,
    when talking about the preview monitor I meant the left one in
    Premiere.
    I tried a lot of things but the results were still the same:(
    The only solution that showed some improvement was when I exported
    the finished project from Premiere to a quicktime file, animation
    preset, and millions of colors +. But only when I would not
    deinterlace it. Still, not deinterlacing made it look slightly better
    but then you could see the lines and some artifacts were added:(
    Any ideas?
    Thank you again!
    AVL
  • Vince Becquiot
    July 12, 2007 at 11:37 pm
    That sounds pretty normal to me. Interlacing will of course be seen on a computer. De-interlacing will cut your resolution to nearly half.
    No artifacts should be added however. Make sure you unchecked “always recompressed” in the export menu, and of course, make sure you are using 100% quality.
    Vince
