Activity Forums Adobe Premiere Pro Premiere 6.5
  • Premiere 6.5
    Posted by Roberta Cantow on May 27, 2005 at 5:12 pm
    I am having trouble getting smooth results with the Planar RGB compression when exporting to Quicktime. I need to use this partciular compression for reasons I won’t explain here.
    Any suggestions on what might be causing it to come out jerky and stuttering?
    Dan Plonsker replied 21 years, 3 months ago 2 Members · 3 Replies
  • Dan Plonsker
    May 28, 2005 at 9:38 am
    Must have more details. what are your seetings? what are originals files? DV? frame size? etc.
  • Roberta Cantow
    May 28, 2005 at 2:32 pm
    Thanks for trying to answer my question.
    All images purchased from istockphoto.com
    All are stills, animated in Premiere.
    72dpi. Resized to 720 x 480.
    R.Cantow
  • Dan Plonsker
    May 28, 2005 at 5:44 pm
    someimes animating stills are a problem with premiere. see if the same happens if the stills don’t move. check when they are smaller in the frame and if they are in full size.
