Activity Forums Adobe Premiere Pro premiere 6 unable to connect to capture driver
  • premiere 6 unable to connect to capture driver
    Posted by Lee Peeler on September 13, 2007 at 4:01 am
    I just purchased a HP Pavilion A6130n PC with Windows Vista. I got all my software loaded and when I go to capture video from my Sony DSR 11 VTR in to Premiere the video window does not show up in the capture window with the controls. I have control over the deck with the capture controls but the video can’t be seen. In the settings for the capture it says “unable to connect to capture driver” Any suggestions?
    Ben Womack replied 17 years, 7 months ago 4 Members · 3 Replies
  • Vincent Rosati
    September 15, 2007 at 1:46 am
    Try going into Project Settings/General, and click the Playback Settings button to ensure it’s set to play on desktop.
  • Rachel Odonnell
    December 3, 2008 at 8:57 pm
    Hello
    I have the same problem I have even used the editing software that came with my laptop and that works. I want to use premier because it is what i used at school. Did you have an answer to your problem. Any help would be great.
    thanks rachel
    celestialspacechild@yahoo.com.au
  • Ben Womack
    February 16, 2009 at 5:42 pm
    I had the same issue with Premiere. You have to run Premiere as Administrator in Vista in order to capture. Browse to Premiere through Explore, right click and choose “Run as Administrator”
