Activity Forums Adobe Premiere Pro Premiere 6
  • Premiere 6
    Posted by Mandla Bolekaja on November 30, 2012 at 2:41 am
    Working on a project for a client. Downloaded assets from ftp server onto my harddrive. I can see and hear all the clips when I click on them individually on my hard drive.
    When I open the project file he sent also via ftp that includes those clips, that I “Link Media” to assets that I have on my hard drive all I see in the CS6 project are green clips.
    Everything in the bins and on the timeline is green. When I play the timeline or a clip in the bins I can hear the audio but I have no video just a green clip.
    Does anyone have a solution to this? I am totally stumped and frustrated.
    System: iMac
    Mountain Lion OS X 10.8.2
    3.06 GHz Intel Core 2 Duo
    4 GB 1067 MHz DDR3
    ATI Radeon HD 4850 512 MB
    Here is file information of clips I am working with. Project was shot with HDSLR cams.
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42
    File size : 5.55 MiB
    Duration : 16s 810ms
    Overall bit rate : 2 767 Kbps
    Encoded date : UTC 2012-11-28 06:56:29
    Tagged date : UTC 2012-11-29 22:43:28
    �TIM : 00:00:00:00
    �TSC : 24000
    �TSZ : 1001
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : Main@L4.2
    Format settings, CABAC : Yes
    Format settings, ReFrames : 3 frames
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 16s 767ms
    Bit rate mode : Variable
    Bit rate : 2 576 Kbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 23.976 fps
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.052
    Stream size : 5.15 MiB (93%)
    Language : English
    Tagged date : UTC 2012-11-28 06:56:29
    Audio
    Format : AAC
    Format/Info : Advanced Audio Codec
    Format profile : LC
    Codec ID : 40
    Bit rate : 192 Kbps
    Maximum bit rate : 249 Kbps
    Channel(s) : 2 channels
    Channel positions : Front: L R
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Stream size : 389 KiB (7%)
    Language : English
    Mandla
    MB
    Walter Biscardi replied 13 years, 9 months ago 2 Members · 1 Reply
  • Walter Biscardi
    December 12, 2012 at 2:00 am
    Generally hearing audio with no video means you don’t have the proper codec on your machine to see the video or the clips are corrupted.
    Can you send one clip into Adobe Media Encoder and convert it to something else you absolutely know works on your machine? In my case I would convert it to Apple ProRes or H264 because I absolutely know those types of files work on my machine. Then take THAT clip into Premiere Pro and see if it works.
    If it does, that means there is something about the original files that Premiere Pro doesn’t like. At that point, I would go ahead and convert all the files in AME and edit using the new files.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author, Chef.
    HD Post and Production
    Biscardi Creative Media
    “This American Land” – our new PBS Series.
    Blog Twitter Facebook
