Activity › Forums › Adobe Premiere Pro › Premiere 2019 lagging
Posted by Nancy Trombley on July 10, 2019 at 1:17 pmHello,
I am having a problem with Premiere timeline lagging. I can scrub the timeline but the cursor takes time to catch up and then premiere crashes. I am using the Mac trashcan, OSX sierra, 64GB of RAM. Has anyone experienced this problem and is there a setting that might need to be changed.
ThanksMike Janowski replied 7 years, 1 month ago 7 Members · 6 Replies -
Sam Nevens
July 10, 2019 at 6:38 pmThis happens to me sometimes with 4K footage. If your footage is 4k, try changing the playback resolution, or make proxies of the footage and edit with those.
Todd Perchert
July 10, 2019 at 7:17 pmSo you’re on Sierra? OSX v10.12? What version of Premiere? For Premiere 13.1 and newer, Adobe has OSX 10.12 as the very minimum. OSX 10.13 High Sierra or newer for hardware acceleration.
https://helpx.adobe.com/premiere-pro/system-requirements.html
TC
Eric Santiago
July 10, 2019 at 7:46 pmNeed more info as to what your files are and where they are residing.
And make sure your OS matched the version. -
Mark Foerster
July 13, 2019 at 4:02 pmNancy I am editing a 4k project and proxies were easy and saved the day – really seamless and you can put a water mark on them (when making them in adobe encoder) – you can also put a “hot” button on the program window to switch back and forth
Mark Foerster
Toronto -
Nina Lucia
July 14, 2019 at 6:32 amHm… I’ve already made my proxies, but how do you put a watermark on them?
And when you say make them in media encoder, is it okay to send them to encoder from Premiere? I did the command in Premiere but the encoding was done in media encoder. Sorry if this is a dumb question, I come from the land of Avid.
Mike Janowski
July 30, 2019 at 1:53 amDisagree. OS 10.12 Sierra works fine with 13.x. Been using it with a low-end Trashcan and the D500 video card and it works fine.
Lagging playback issues are generally caused by media drive issues. What sort of media drives are you running?
