Activity Forums Adobe Premiere Pro premiere 1.5 to audition workflow
  • premiere 1.5 to audition workflow
    Posted by Dustin on April 6, 2005 at 4:09 pm
    Does anyone know of a streamlined workflow to go between premiere and audition, using premiere to do video and audio editing, and going to audition to do further audio editing and audio effects processing. Is there anyway to keep the audio cuts in audition, the way they appear in premiere, in case after further editing or effects processing, audio cuts need to be moved to fit better with the video…
    Ebarfield replied 21 years, 5 months ago 3 Members · 2 Replies
  • Steven L. gotz
    April 6, 2005 at 6:54 pm
    I will generally use “Render and Replace” which turns the audio into a WAV file. Then “Edit Original” will work if you have Windows set up to use Audition by default for WAV files.
    Steven
    Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Ebarfield
    April 6, 2005 at 6:58 pm
    From PP, I always just right-click on the audio track and choose “edit original”, which allows me to edit the audio in audition, since audition is my default audio app for most formats, such as .wav, .mp3, etc. When I save the changes in audition, the changes are automatically changed in PP audio track. If it were a cut I made in Audition, I make sure in PP that the new length is adjusted there. This is all I know about that. I don’t think I quite understood the last part of your question.
    egb
