Activity Forums Adobe Premiere Pro premier wont play time line
  • premier wont play time line
    Posted by Scott Boyd on April 29, 2005 at 1:38 pm
    Hi ALl
    can some one help, I am useing prem6.5, it was working fine then for no reason the time line suddenly wont play at all.
    I have tried the normal stuff like deleting the pref file, reboot and even removing and re-installing premier. even after the install the problem is still there( the time line just wont play)
    any one have any ideas
    Mike Velte replied 21 years, 4 months ago 4 Members · 5 Replies
  • Aanarav Sareen
    April 29, 2005 at 2:29 pm
    Does this happen in a particular project or in all your projects?
  • Leon Willis
    April 29, 2005 at 2:59 pm
    i had the same problem and the only thing that worked was to install prem pro or a different version of prem. If this is a possibility for you?
    Lenny
  • Mike Velte
    April 29, 2005 at 7:46 pm
    I would be concerned about a unresposive hard drive where the source files are located.
    What capture card are you using?
  • Scott Boyd
    April 30, 2005 at 12:42 pm
    THe problem happens in all projects and on all users, most of the other features are working, premier just wont Play any thing!
    Im using Pinnic DV500 capture card I have a copy of prme pro 1.5 but the dv500 softwear wont load into it. I have loaded prem pro 1.5 and It works fine.
  • Mike Velte
    May 3, 2005 at 11:28 am
    Pro wont work with 1.5 because Pinnacle dropped driver support for the DV500 and Pro-One a while back.
