Activity Forums Adobe Premiere Pro Premier pro timeline and monitor disappear
  • Premier pro timeline and monitor disappear
    Posted by Ponyack on July 13, 2005 at 1:50 am
    This is something new, at times i may touch the timeline and then everything diappears, when i go to view and try to get the timeline and monitor to comeback nothing. the project remains open and i can save the work…like i said this only started a few days ago
    thanks
    ponyack
    Roundy replied 21 years, 2 months ago 6 Members · 6 Replies
  • Aanarav Sareen
    July 13, 2005 at 3:50 am
    Have you installed anything new since this has been happening? Try doing a system restore and if that does not help, reinstall the application.
  • R. Hewitt
    July 13, 2005 at 10:05 am
    Have you recently updated your graphics card driver?
  • Blast1
    July 13, 2005 at 11:32 am
    Before drastic solutions try resetting the perferences, with PremierePro x.x hold down the shift key when starting premiere and hold till the recent/new project window appears, as it will reset some parameters to default always check the location of things like scratch disks, etc.
  • Ponyack
    July 13, 2005 at 10:41 pm
    Thanks for all the replies.
    I have not updated my graphics card, its an ATI 9800 pro, that i installed 7 months ago…
    i did try the Holding shift down on start up but it still disappears, i can try a re-install, like i said this is something new that has only started ovet the last week or two.
    ponyack
  • Wolf
    July 14, 2005 at 5:12 am
    i had also the same problem, but i don
  • Roundy
    July 15, 2005 at 10:15 am
    Try this,
    In the Project window:
    To display the Source Window, select your file and right click on the thumbnail at the top left of the project window, select ‘Open in Source Monitor’ from the drop down menu.
    In the Project window, you should have a Sequence (and number), if you don’t, you haven’t created one yet, so, right click in the lower half of the Project window, select New Item, and then Sequence. You can Number it what you want. This will display the timeline.
    Only had Premiere a week. It’s a nightmare, help is useless, think this is to force you to buy their teachingf and ebooks. Load of rubbish, it just puts people off!
    Roundy
