Activity › Forums › Adobe Premiere Pro › Premier Pro Help Required.
Posted by Muhammad Imran on April 3, 2009 at 6:27 amHi All,
I have audio video files in preimer and i want to fade out audio when video ends. Can anyone pls tell me how to do this ?
Imran
Rick Godin replied 17 years, 5 months ago 4 Members · 3 Replies -
Mike Velte
April 3, 2009 at 10:48 amExpand the audio track to reveal the yellow volume rubber band. Use the CTRL key to modify the selection tool and click on the rubber band to add 2 keyframes. Drag the second keyframe down and to the right into the bottom/right corner of the track.
Eddie Lotter
April 3, 2009 at 12:57 pmSee also Fade in or fade out clip audio in the Premiere pro Help.
You will also find links to many free tutorials in the PremiereProPedia that will quickly show you how things are done in Premiere Pro.
Cheers
Eddie -
Rick Godin
April 3, 2009 at 4:25 pmmove the playhead to the end of the clip; highlight the audio track you want to fade; hit CNTRL-SHIFT-D; and the default audio transition will be added to end of clip. quick and dirty.
You never get hurt in the air!
