Activity Forums Adobe Premiere Pro Premier Pro ‘”Export to tape” greyed out
  • Premier Pro ‘”Export to tape” greyed out
    Posted by Marc Poliquin on April 3, 2007 at 3:38 pm
    Hi:
    We edit SD and HD using the axio boxes, and have never had trouble printing to tape. Suddenly, out of the blue, “export to tape” is greyed out — on all jobs, even ones that I’ve recently printed. I’ve reinstalled the utils, switched bobs, etc…Nothing seems to work. Any suggestions?
    Thanks.
    Marc
    Pat Mcgowan replied 19 years, 5 months ago 4 Members · 3 Replies
  • Steven L. gotz
    April 3, 2007 at 7:58 pm
    Sounds like an Axio problem. Or, is it possible your firewire cable fried?
  • Eric Jurgenson
    April 5, 2007 at 6:21 pm
    Make sure you have a device control device selected. If “none” is selected, the export to tape will be greyed out.
  • Pat Mcgowan
    April 16, 2007 at 8:23 pm
    In PPRO, the Capture utility settings seem to overide machine control settings. So, if you last used Firewire control in capture and you try to Export to Tape using serial control it won’t work. You must go into Capture and set the machine control settings to whatever you want to use in Export to Tape.
