Premier Pro CS6 and Motion 4 templates
Hi
I am trying to add a template I created in Motion 4 to Premier Pro CS6. It has logos, text and drop zones I created.
Although it goes into CS6, it’s not right as it’s 1440 x 1080 and my CS6 project is AVCHD 1920 x 1080.
I can’t seem to figure out how to make it work – I even tried nesting the Motion file (even a mov file from the template) into a new sequence with the CS6 project open….it still retains the 1440 dimension. I tried to right click on the file in the timeline and make it match sequence (frame size I think from memory) – no luck.
I also tried in Motion 4 to find a button to change the setting from 1440 to 1920 – no luck at finding a button.
This is a template I’ll always need to use as I need the logo, text and drop zones I created (it works like the other Motion templates with drop zones).
Thanking you all in advance for your assistance.
