Activity Forums Adobe Premiere Pro Premier Pro CS6 and Audio Levels on Multiple Clips
  • Premier Pro CS6 and Audio Levels on Multiple Clips
    Posted by Sheree Day on July 10, 2014 at 7:01 am
    Hi
    I have a series of audio clips on a timeline (about 20). I need to increase the levels so they are the same amount for e.g. they are presently -5db but it is too low and I need to increase them all to around 4db.
    Coming from FCP7 I used to select all clips and easily change the levels at once to what I needed, even if the clips were of different levels.
    Is there something similar in PPCS6? I tried googling it and also looking on the forums here but couldn’t find an answer.
    Thanks in advance for your help. Much appreciated.
    Richard Herd replied 12 years, 2 months ago 2 Members · 1 Reply
  • Richard Herd
    July 11, 2014 at 6:29 pm
    Can you use the audio mixer? As long as they are all on the same track, you can boost that track. You can even get more fancy and add effects, buses and such.
