Activity Forums Blackmagic Design Premier Pro cs5.5 and Decklink not working
  • Premier Pro cs5.5 and Decklink not working
    Posted by Davib Le roux on January 18, 2012 at 12:53 pm
    I am using a Decklink Studio card to send SDI out to an SNG van from my timeline.
    This worked perfectly for FCP7, but now we have switched to premiere for faster AVCHD editing/ingesting.
    The problem is that although i have downloaded the latest software from decklink, Premiercs5.5 doesn’t seem to recognise the video side of the Decklink card. It allows me to map audio out through Blackmagic Audio, but under Device control only fives me the DV firewire option or “none”.
    Can anyone shed some light on this issue?
    Andreas Wojtaschek replied 14 years, 8 months ago 2 Members · 4 Replies
  • Andreas Wojtaschek
    January 19, 2012 at 11:05 am
    you have to use a “Decklink” Timeline in Premeiere CS5.5 in order to use the SDI outputs of the card.
    If you create a new timeline you should see a “Decklink” section there and if you click thle little plus you see many different formats like SD and HD. Just create a Decklink timeline and start editing. Your Decklink outputs should work then.
    Regards
    Andreas
    Entertainment Producer IHK
    mindandvision
  • Davib Le roux
    January 24, 2012 at 8:55 am
    I do not have any of these declink or blackmagic options, it onl lists under audio hardware. Seems i am not the only one with this issue.
    January 24, 2012 at 11:44 am
    Try to reinstall the Decklink software (uninstall and then reinstall).
    If you create a new sequence in Premiere you should have a preset that is named “Blackmagic” within that you can select multiple formats (SD HD…).
    Create a blackmagic Timeline and you get your SDI output.
    Regards
    Andreas
    mindandvision
    January 24, 2012 at 11:48 am
    Here is a screenshot:
    mindandvision
