Activity Forums Adobe Premiere Pro Premier Pro CC cutting video in play preview
  • Premier Pro CC cutting video in play preview
    Posted by Firas Sameer on November 3, 2015 at 7:35 pm
    Hi there, I know this problem has been posted a lot over the internet but all the tricks I’ve found in the forums and websites did not solve my issue,
    my problem I had a premier pro cs6 before till I got one of my clients footage 2k shot using Alexa ARRI camera, the footage couldn’t be imported into premier pro CS6 at all.. so I had to remove premier and installed premier pro CC which did accepted the footage files BUT… having lots of issues using preview play , the all over the time line the video is cutting and lagging and never became normal even after trying all what I found over the internet..
    I also worked on two different projects with HD quality on a site editing imac it was perfect using premier pro CS6 but when I brought the project files into my imac and opened it in my premier cc I found both projects having the same exact issue since the last upgrade..
    Please advice how to solve this issue as I have lots of pending work ..
    my imac specs is:
    processor 3.4 Ghz i7
    Ram 32 GB DDR3
    Graphics NVIDIA GeForce GTX 680MX 2048 MB
    OS. X version 10.9.5
    Using Seagate external storage over local network (I used it before with different project without any issues)
    Firas Sameer replied 10 years, 10 months ago 2 Members · 2 Replies
  • Ann Bens
    November 3, 2015 at 7:42 pm
    Turn off Composite preview while trim under the wrench in the timeline.
    See if that is any better.
    Adobe Certified Expert Premiere Pro CS6/CC
    Adobe Community Professional
  • Firas Sameer
    November 3, 2015 at 7:49 pm
    There are three options there:
    Composite Video
    Alpha
    Multi Camera
    which one to select? there isn’t any “Composite preview while trim” option there !!
    Please advice
    thanks
