Activity Forums Adobe Premiere Pro Premier Pro – Capture Problems
  • Premier Pro – Capture Problems
    Posted by Rd44/opc on September 6, 2006 at 8:54 pm
    Seems I am having problems capturing my footage (I am using an external hard drive). I can only download 18 minutes and then it shows an error, I save the footage I have capture it to my project file, rewind the footage back a few frames (before the error), and it will plays through without any problems. I’d like the ability to download the entire tape in one file and then onto a DVD.
    Is it my camera (Canon XL1s), coding the tape, or is it something that I am overlooking with Premier Pro?
    Rd44/opc replied 19 years, 11 months ago 3 Members · 7 Replies
  • 7 Replies
  • Andre Gagnon
    September 6, 2006 at 9:50 pm
    [RD44/OPC] “Is it my camera (Canon XL1s), coding the tape, or is it something that I am overlooking with Premier Pro?”
    None of the above.
    Your hard disk are formatted with the Fat 32 file system that has a file size limit of 4 GB that result in
  • Julio Crespo
    September 6, 2006 at 11:36 pm
    Yes, absolutly true. type convert drive_letter: /fs:ntfs in the command prompt
  • Rd44/opc
    September 8, 2006 at 3:43 pm
    Thanks for the info – tried with my C drive and it’s already NTFS. Since I’m capturing using my E drive; it tells me it is FAT32. Any way of converting this? I’m still stopping at 18 minutes.
  • Andre Gagnon
    September 8, 2006 at 7:40 pm
    [RD44/OPC] “Since I’m capturing using my E drive; it tells me it is FAT32. Any way of converting this?”
    You must convert your E drive since you are capturing on it!
    In Windows, go to start, click on the Run button, in the text box that pops-up write convert E: /fs:ntfs, click OK.
    Windows will convert your drive.
    You should convert all your other drives that are not already NTFS.
  • Rd44/opc
    September 9, 2006 at 11:44 pm
    I tried previously, and again Andre and I still get the following message:
    “This type of the file system is FAT32”
    “Enter current volume label for Drive E”
    I should have mentioned this before.
    RD
  • Andre Gagnon
    September 10, 2006 at 6:14 am
    [RD44/OPC] “”Enter current volume label for Drive E””
    The volume label is the name that you have given to your drive like System or A/V or Capture as examples.
    For your info, here are the exact instructions you find in Windows “Help and Support on how to convert a Hdisk from the FAT32 to the NTFS system:
    [Quote]
    To convert a volume to NTFS from the command prompt
    Open the Command Prompt window.
    In the command prompt window, type
    For example, typing convert E: /fs:ntfs would format drive E: with the ntfs format.
    Notes
    To open a command prompt, click Start, point to All Programs, point to Accessories, and then click Command Prompt.
    You can convert FAT or FAT32 volumes to NTFS with this command.
    [Unquote]
  • Rd44/opc
    September 11, 2006 at 12:49 am
    Andre, finally got it and thank you. I had to rename the E drive and get rid of all open handles (Y/N), and dismount everything. To test, I converted once again and the prompt stated that the E Drive was already ntfs.
    Thanks again Andre, been loads of help.
