Activity Forums Adobe Premiere Pro Premier Pro Audio Balance
  • Premier Pro Audio Balance
    Posted by Boris Isakov on March 21, 2009 at 5:35 am
    Hello,
    I have a clip that I imported into Adobe Premier Pro CS4 that has unbalanced audio. How do I balanced that clips audio within the clip. The knobs in audio mixer does not do that trick because the dialogue on the clip for some reason comes up only of the left speaker and the music on both.
    Any suggestions?
    -Boris
    Boris Isakov replied 17 years, 5 months ago 2 Members · 4 Replies
  • Mike Velte
    March 21, 2009 at 11:07 am
    Select the video clip in the Project window; choose Clip>Audio Options>Break out to Mono. THen you can modulate the gain of each track separately.
  • Boris Isakov
    March 21, 2009 at 7:19 pm
    I know there should be an option to balance the audio between the channels.
    I selected the clip > clip>audio options>>break to mono is grey.
  • Mike Velte
    March 22, 2009 at 10:19 am
    Did you select the clip in the PROJECT window and not the TIMELINE?
  • Boris Isakov
    March 22, 2009 at 2:36 pm
    I figured it out. Went into effects and choose either fill right or left left under audio effects. Then just dragged the effect onto the clip.
