Activity › Forums › Adobe Premiere Pro › Premier Pro & Aja LHe not playing nice together…
  • Premier Pro & Aja LHe not playing nice together…
    Posted by Jeremy Rowell on March 21, 2012 at 4:27 pm
    Prpro 5.0.3 and Aja 9.1.
    Can not get external monitor to work at all. Created a new sequence and choose Aja… no luck. internal monitor and external monitor do not work at all. any help would be appreciated, I am not well versed in Premier.
    Erik Mickelson replied 14 years, 6 months ago 5 Members · 9 Replies
  • 9 Replies
  • Shane Ross
    March 21, 2012 at 4:53 pm
    Get the most current LHe drivers from AJA? And the Adobe Plugin? Install, then restart the computer.
    Shane
    Little Frog Post
  • Jeremy Rowell
    March 21, 2012 at 5:15 pm
    Downloaded the latest Aja drivers.
    As for the Premier Plug in… I’m a bit confused there. Aja shows up in the Sequence menu.
    Where are the plugins located?
  • Jeremy Rowell
    March 21, 2012 at 5:37 pm
    Found plugins on Aja site. Downloaded and installed. Restarted… no dice. I get no output to monitor.
  • Tom Daigon
    March 21, 2012 at 5:39 pm
    FYI, you must be using an AJA sequence in order to get play out to your monitor. Just a regular Adobe sequence wont owrk.
    Tom Daigon
    Avid DS / PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Maxx Digital / Areca 8tb. raid
    Kona 3
  • Chris Borjis
    March 21, 2012 at 5:54 pm
    and if that doesn’t work, contact aja email support.
    they respond very quickly.
  • Tom Daigon
    True Chris, their support is the best!
    Tom Daigon
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Kona 3
  • Jeremy Rowell
    March 21, 2012 at 6:57 pm
    Their support was Awesome and fast. Turns out my drivers were too new. Needed to step back a version as well as step the plugins back. Works ok now… although the audio won’t play sometimes…
  • Chris Borjis
    March 21, 2012 at 8:59 pm
    [jeremy Rowell] ” although the audio won’t play sometimes…”
    I get that occasionally with cs 5.5 and my LHe
    I’m hoping the next drivers for cs 6 are nearly
    flawless as they were for fcp.
  • Erik Mickelson
    March 24, 2012 at 7:50 am
    Actually AJA told me that the LHe was EOL’d. They said there would be no more updates for that card and that I was free to buy a new LHi or LHe Plus from them, if I so desired. Thanks AJA! )
    CrippleBook Pro 2.3Ghz i7, 8GB ram, SLeopard 10.6.8, FCPStudio 3, QT 7
