Activity Forums Adobe Premiere Pro Premier Pro 7 Interface missing without any warning
  • Premier Pro 7 Interface missing without any warning
    Posted by Mohamed Bilal on July 27, 2007 at 11:06 pm
    I am Using Premier Pro7 with the following System Specs
    Pentium Dual Core 3Ghz
    Intel 945 Mother Board
    2GB DDR2
    500GB Sata HDD
    Geforce 6200 Graphic Card With Turbo Cache memory
    etc…
    My Problems are at the time of Editig the Premier pro Interface is missing without any warning and also when i split the video clip using the shot cut or with mouse, it is 2 or 3 frames left or right of the cursor…Please some one help me…
    Mohamed Bilal replied 19 years, 1 month ago 4 Members · 4 Replies
  • Steven L. gotz
    July 28, 2007 at 12:13 am
    It is a very old program and it is difficult to help you. I suggest upgrading to the latest version (CS3).
    Steven
    https://www.stevengotz.com
  • Tim Kolb
    July 28, 2007 at 1:54 am
    Have you tried reinstalling the program?
    this is an excellent first step whenever software starts to act up…
    You might also try starting while holding down the SHIFT key (is that the one? Somebody correct me if I’m wrong please) to reset the prefs file.
    If you are only having the issue inside one project, that project may be corrupt. Try importing that project into a new one and see if the behavior continues.
    TimK,
    Director,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
    http://www.focalpress.com
    http://www.classondemand.net
  • Blast1
    August 2, 2007 at 9:01 pm
    [Tim Kolb] “You might also try starting while holding down the SHIFT key (is that the one? Somebody correct me if I’m wrong please) to reset the prefs file.”
    For PremierePro thats correct, it recreates the Plug-in Cache file(preferences), when Adobe products get wonky this is one of the first thing to try, there are different key strokes for Photoshop Illustrator, etc.
  • Mohamed Bilal
    August 6, 2007 at 8:15 pm
    I am Using Some Plugins and some files with it..So it is very difficult to change to CS3…Please some one help me…
