Activity Forums Adobe Premiere Pro Premier Pro 1.5 and High Definition – Is it possible?
  • Premier Pro 1.5 and High Definition – Is it possible?
    Posted by Deborah on November 7, 2005 at 12:54 pm
    Hi everyone!
    I currently use Premiere pro for DV with this resolution: 720×576 (PAL).
    I’d like to buy a 1080i camera.
    My question is: is this resolution supported by Premiere?
    If yes, how can I turn it “on”?
    Thanks for help!
    Debbie!
    Deborah replied 20 years, 10 months ago 2 Members · 2 Replies
  • Tim Kolb
    November 7, 2005 at 1:22 pm
    If you want to buy an HD”V” camcorder…then you can simply download the Ppro 1.5.1 free upgrade from Adobe and you’re set to go… If it turns out you like some more speed, then you can purchase AspectHD from CineForm to run with PPro and accelerate the process considerably.
    If you are considering HDCAM or DVCProHD, then you would need a compatible HDSDI card…I believe that BlueFish444, Decklink and AJA all have models compatible with PPro. I have an AJA.
    TimK,
    Kolb Syverson Communications,
    Creative Cow Host,
    2004-2005 NAB Post Production Conference
    Premiere Pro Technical Chair,
    Author, “The Easy Guide to Premiere Pro” http://www.focalpress.com
    “Premiere Pro Fast Track DVD Series” http://www.classondemand.net
  • Deborah
    November 8, 2005 at 1:37 pm
    Thanks for your help!
    Debbie!
