Activity Forums Adobe Premiere Pro Premier CS5.5 sound playback stuttering, dropping out
  • Premier CS5.5 sound playback stuttering, dropping out
    Posted by Justin Mettam on February 3, 2012 at 9:45 pm
    MacBook Pro
    Processor: 2.2 GHz i7
    OS: Lion 10.7
    Memory: 4GB
    Ever since I installed Premiere CS5 I have had problems with my audio stuttering/spitting and dropping out.
    note: The video sequence plays back fine.
    I am not using any special audio card.
    Any suggestions ?
    ps… I am new to Premiere so I haven’t set up anything special with my preferences.
    Justin Mettam replied 14 years, 7 months ago 2 Members · 3 Replies
  • Angelo Lorenzo
    February 4, 2012 at 7:59 am
    Could possibly be a bad ingest. Premiere conforms all audio to a media cache for editing.
    In Premiere, go to Edit > Preferences > Media and look at the first folder listed under “Media Cache Files” and clear this folder out. All cache files will be forced to regenerate when the projects are re-open.
  • Justin Mettam
    February 5, 2012 at 11:37 pm
    Thanks for replying Angelo.
    I cleared out the “Media Cache Files” (at least I pressed the button to clear out the cache). I also navigated to the place where the media cache files are kept, but nothing was there. Maybe ‘Lion OS’ hides these files from my view, Do you know ?
    It is very strange because I know the .mov file has good audio. Because I can play it in iPhoto.
    Other .mov files shot with the same device import and play fine, its just a few that don’t.
    I do think it has something to do with a cache file somewhere. I can’t seem to see these cached files.
    Is there a setting in my Finder that hides them from my view, much like the PC does ?
    Are there any tricks so I can see explicitly where this exact cache files is kept. Or can I make it not cache just for a test ?
  • Justin Mettam
    February 6, 2012 at 12:11 am
    Ok This is what I have discovered.
    The problem was, I was trimming some of the footage in iPhoto before importing into Premier.
    Even though all of the .mov files where created with the same device some of them where edited/trimmed in iPhoto. These trimmed files are the ones giving me problems. So fortunately Mac let’s me source the original files, and it is these original files I need to use and then retrim them in Premiere.
    I sure hope this information can save others from frustration..
