Activity Forums Adobe Premiere Pro premier automatically adds a lut issue.
  • premier automatically adds a lut issue.
    Posted by Jimmy Dunlow on October 13, 2020 at 12:41 pm
    i have log footage but when i import into premier it automatically adds a lut that i can’t delete.
    If i turn off the effects you can see the clip as is should be but i can’t delete this automatically added effect. see screen grab on the right is how it should look on the left premiers added effect, do i have something turned on in import settings maybe, Any ideas? Thanks
    Matthew Rogers replied 5 years, 11 months ago 2 Members · 1 Reply
  • Matthew Rogers
    October 13, 2020 at 1:17 pm
    If you open those clips up in the source window then check the Effects tab you should see the LUT as a Lumertri effect and turn it off. Alternatively you can right clip the clip in the library and choose “Disable Master Effects” and that will disable the LUT.
