Premere Pro CS3 – upgraded to 16 GB of RAM and still slow
Today I just upgraded my work computer (Vista 64-bit Home) to 16GB of RAM, along with a Sparkle GeForce 9800 GT video card (1GB) (GDDR3).
Plus this system is Quad-CoreI was hoping to see Premiere CS3 and After Effects CS3 run with flying colors. When I opened up a session (720p) I was quickly saddened to see it running very similar to how it was previously with only 6GB and a super date cheap ATI card. Un-rendered, I was hoping to see some improvements. But there were none (as far as I could tell). And rendering seemed to take just as long as before. After rendering it did play nicely. And AE, I didn’t see much improvement either. That is with Multithread turned on and maxed out at 4GB in the memory settings. Playing from RAM seemed slightly faster when rendering to play 1080p video, but still took very long. From Render Cue, I did notice in the log from previous upgrade renders. It went from over six minutes to just under 6 for a shot. This is a 12 second clip.
Am I missing something? Is there a way to actually see improvements after this expensive of an upgrade? Is it because I’m using Vista Home Edition (64-bit) instead of Pro?
How can I take advantage of this processing power? I need to be able to work faster for bigger projects. Especially in Premiere.
Please give me some insight if you can. My boss is sort of impatient and is already talking about using the RAM chips elsewhere since it seems to be such a waist so far.
Thanks.
