Activity Forums Adobe Premiere Pro Premeire pro cs5.5 bugs
  • Premeire pro cs5.5 bugs
    Posted by James Clarke on May 12, 2012 at 12:43 am
    Thankfully I’ve figured out a bunch of problems, and my rendering abilities are back, plus learned a bunch of new things. but these are my leftover issues from my campaign for a clean render!:)
    -Export having transparent bent moving lines on certain parts of the footage that weren’t on original footage, and only sometimes appear on export.When I do a test render of a small 10 second portion, they appear in mpeg 2 renders, but not in h264. When I render in half hour sections, lines appear in both.
    – Timeline continually forgetting then remembering where a clip is, making me unable to render that part.Unless it seems, I render at a time when it remembers.
    -Export upsizing the size of picture on export, and making me need to downsize and re import/export.making it wider and taller from like 100 to 133. After I export second time, it doesn’t change the picture size.
    -Not being able to figure out the best way to reduce black and lighten footage with color correct or other programs.I’m a novice to color correct, but so far it just adds white to the footage and can’t get rid of the extra black that appears when the file is put on a t.v. and blacks into the face of an actor!
    Tom Edwards replied 14 years, 4 months ago 2 Members · 1 Reply
  • Tom Edwards
    May 12, 2012 at 3:03 am
    i’ve encountered the timeline issue as well.
    never used to happen and i haven’t run an update.
    odd.
    kinda like taking your car in when it makes some weird noise.
    can’t seem to regularly duplicate the problem.
    that tells me it’s operator error. and i’m fine with that.
    but if i knew what the operator was doing wring, i’d hit him over the head and tell him to stop.
