Activity › Forums › Adobe Premiere Pro › Premeire cs6 Bloating again – Beware when using Warp Stabilization
Walter Soyka replied 12 years, 4 months ago 11 Members · 22 Replies
Ryan Patch
May 19, 2012 at 5:07 pmThis is what we were all doing in 5.5 when only AE had the stabilizer. Worked fine.
Erik Lindahl
May 21, 2012 at 2:45 pmI have the exact same issue with After Effects CS5.5 given I’m using very little media (10-60 second commercial, i’m usually using less than 5 minutes of media) – the project and especially save time of the project grows a lot when using the filter.
If this scales with the amount of media – PPCS6 projects will scale like crazy. Do you have issues with long saving times as well?
Peter Corbett
May 24, 2012 at 3:45 amI am getting the same hideous bloating on Mac and I’m not even using warp. My project jumped from 120mb to 5.88Gb overnight. The project take 30minutes to save or open. I am not impressed.
Peter Corbett
Powerhouse Productions
http://www.php.com.au -
Tom Daigon
May 24, 2012 at 4:05 amAdobe statement that might relate to topic…
There’s a known bug having to do with preview files & using Save As frequently – it’ll double the number of preview file references incorrectly on each iteration. This will be fixed in the next update. Considering the amount of cuts with software effects, I’m betting that this is what you’re hitting.
Importing your project into a new one is a good suggestion, it’s likely to leave behind any preview file references.
Tom Daigon
PrP / After Effects Editor
http://www.hdshotsandcuts.com
Mac Pro 3,1
8 core
10.7.3
Nvidia Quadro 4000
24 gigs ram
Maxx Digital / Areca 8tb. raid
Kona 3 -
Tony Bernard
August 22, 2012 at 3:26 amI am cutting a feature in CS6 and have been having this project file size problem. I am up to date and not using any warp stabilizer effects. I am not using Save As all the time either. The only thing I could think of is that it is because the project was originally started in FCP7. It was migrated to CS6 via an xml. It was working great, but I noticed the project file size started to get bigger and bigger. At the moment I am at about 2gb. I am not using really any plugins or effects. Just some 3 way color correctors and a couple looks effects here and there, but probably only 5 or so in the entire film. There are a ton of cuts and tracks. I assume this could be the problem? I have done features in CS5.5 before and never had this many problems. I am going to try the opening it in a new project strategy. I hope this works, because it is taking ATLEAST 30 minutes to save every time and if it pops up with an auto save while I am in the middle of something and I tell it to cancel it tends to freeze the program and I have to force quit and lose everything I had just done. This is NOT acceptable and I have contacted Adobe on this issue on several occasions and not heard anything back from them. If this doesn’t work I am going to try jumping out the window. I will post back with an update as to which route worked.
Tony Bernard
August 22, 2012 at 8:27 pmHoly crap that worked like a charm. Took forever to pull my sequence in, but it only takes about 15-20 seconds to save now instead of at least 20 minutes! Thanks Tom you’re a life saver!
Nadine Van hees
October 15, 2012 at 10:37 pmWhat? what worked like a charm? You pulled your sequence in?
I thought this problem was mine alone and I was ready to slash my wrists because my program has frozen and lost all my edits at least 10 times (most often during saving. I was blaming it on my new iMac (always had a PC before). Now I hear there may be hope. Please let me know.Thanks a ton!
Nadine Van hees
October 15, 2012 at 11:08 pmI’m thinking you mean creating a new project and importing the sequences? I’ll try it. Just forced quit again for a now unknown amount of times. This is killing me.
Garrett Gibbons
May 23, 2014 at 8:59 pmThis is affecting me today, in Premiere CC, using warp stabilizer clips. It’s a nightmare. Adobe is as bloated as this project file has become.
Walter Soyka
May 24, 2014 at 12:28 pm[Garrett Gibbons] “This is affecting me today, in Premiere CC, using warp stabilizer clips. It’s a nightmare.”
All the analysis data is stored in the project file.
I think that handling your stabilization in a separate project (or a few separate projects if you have a lot of them) and rendering intermediates is worth doing to keep the main project file manageable.
Walter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn]
