Activity Forums Adobe Premiere Pro prem pro encounters a serious error and shuts down???
  • prem pro encounters a serious error and shuts down???
    Posted by Stan Weiss on September 24, 2008 at 2:09 am
    I just finished a large project earlier today..now when i go back into prem to re-open the file i get an error message saying that prem pro has enountered a serious error and has to shut down…
    no matter how often i try to open the project i keep getting this message….other projects do open and I can open the auto saved project of this file but I would really like to get to my original!!
    any idead what causes this error message…or how to get around it?
    thanks
    stan
    Eddie Lotter replied 17 years, 4 months ago 4 Members · 5 Replies
  • Mike Velte
    September 24, 2008 at 10:57 am
    Try opening a new project and import the troubled Project file into that.
  • Eddie Lotter
    September 24, 2008 at 1:24 pm
    Another trick is to rename the folder where you source clips reside to “hide” them from PPro. Then, when you open the project, offline all the clips. Does the project load?
    Cheers
    Eddie
  • Stan Weiss
    September 28, 2008 at 1:00 am
    Problem solved…Thanks
    I imported the project into another prem project and it imported with error. Once i had the project I played some of the sequences and found that i had a corrupt jpg file …i deleted that file and now the project opens with errors..
    thanks for all your help!
    Stan
  • Rob De jong
    May 9, 2009 at 9:11 am
    I have experienced the same problem and tried your suggestion. I imported the project into a new project after hiding the source clips. The project loads with all clips offline. But then even when I scroll through the ’empty’ project Premiere CS3 crashes. I have also reinstalled Premiere and defragmentated the system drive. With other projects I can work without errors.
    Would you have any other suggestion?
  • Eddie Lotter
    May 9, 2009 at 4:24 pm
    [Rob de Jong] “Would you have any other suggestion?”
    Try these troubleshooting tips.
    Cheers
    Eddie
