Activity Forums Adobe Premiere Pro Prem Pro CS 3.2 and Cineforms Neoscene: Advice needed/Thanks!
  • Prem Pro CS 3.2 and Cineforms Neoscene: Advice needed/Thanks!
    Posted by Bruce Pelley on August 28, 2011 at 10:11 pm
    My present circumstances require me to be quickly be tutored in order to learn how to use Neoscene with Premiere CS 3.2 so please bear with me. My main questions have to do with what settings are best suited for the source footage and ultimately the end product.
    Source footage on master timeline is Canon A1s HDV @60i
    Length is around 47 minutes/heavily edited.
    Final destination is SD 16:9 (widescreen) to MPEG-2 Dvd
    My first successful attempt did not include interlacing the footage when exporting as “movie” to Cineform AVI. Should I have? Would I have obtained better results considering the end product? Please, what are your thoughts on that?
    Is it proper to choose the timebase as 29.97 fps instead of 59.94 or 60.00?
    What surprised me is the relatively huge amount of HD space taken by the resulting file considering I only selected the “‘High HD” setting in Cineform which is not even in the middle of the quality hierarchy. Almost 49 gigs !! Compare that to using the best quality setting with Adobe Media Encoder rendered as an MPEG which roughly 20 gigs less.
    I was quite dissappointed with what Neoscene did to the opening series of slides as the vibrancy/appearance took quite a hit.
    Also, I do not know if this can be done.
    Can one save sequences independent of projects?
    Is there a way to:
    Export a HDV Sequence (while open on the timeline) in a 60i project to a new project or:
    Or after saving that project, import it into a new 16:9 wide-screen NTSC SD project? I can’t have Premiere Pro launched simultaneously twice right?
    Any advice regarding settings and solutions would be greatly appreciated. Thanks in advance.
    Bruce Pelley replied 14 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
