Activity › Forums › DaVinci Resolve › Prefix Suffix – I just want to add a . !
  • Prefix Suffix – I just want to add a . !
    Posted by Simon Blackledge on March 26, 2013 at 2:31 pm
    So I want the source filename MyWonderfulVFXplate_SH001.mov rendering to
    MyWonderfulVFXplate_SH001.0000.dpx but no..
    ends up as MyWonderfulVFXplate_SH0010000.dpx fail
    Use custom name Prefix /%L doesn add filename :-/
    If I want to add a simple . before the seq numbers I have to turn source name off..
    Any suggestions?
    Ta
    s
    Pepijn Klijs replied 13 years, 6 months ago 4 Members · 6 Replies
  • Eric Hansen
    March 26, 2013 at 3:23 pm
    as far as i know, you can’t use a period because it will think .0000 is an extension.
    a dash is probably your best best.
    e
    Eric Hansen
    Production Workflow Designer / Consultant / Colorist / DIT
    https://www.erichansen.tv
  • Simon Blackledge
    March 26, 2013 at 3:49 pm
    Yeah suppose though nuke handles these fine.
    So.. How to have %L- actually work ? Because use filename doesn’t allow custom prefix/suffix :-/
  • Joseph Owens
    March 26, 2013 at 3:51 pm
    [Eric Hansen] “a dash is probably your best best.”
    Probably legal. Linux/Unix convention, for your consideration, is usually an underscore ( _ ).
    jPo
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
  • Simon Blackledge
    March 26, 2013 at 4:26 pm
    Either way.. adding a . or – or _ to after filename doesnt seem possible.
  • Eric Hansen
    March 26, 2013 at 4:54 pm
    If you’re on a Mac, you could use Name Mangler to insert characters into file names after they’re all exported. I use it all the time for bulk re-naming. not sure how long it will take on a stack of DPX files. depends on how fast your storage is.
    e
    Eric Hansen
  • Pepijn Klijs
    March 26, 2013 at 6:49 pm
    I used ‘automater’ to batch rename files in finder. Pretty easy and already in your OS (assuming you’re on a mac)
    Editor/Colorist, Amsterdam, The Netherlands
    http://www.pepijnklijs.nl
