Activity Forums Compression Techniques Preferred frame sizes and compression format for exhibition display?
  • Preferred frame sizes and compression format for exhibition display?
    Posted by Mike Smith on September 7, 2007 at 10:13 am
    Any thoughts / experience on this?
    The display to be on big a plasma screen – I don’t have a spec on that yet, and obviously need it.
    Playback is likely to be from a laptop so I guess there’s a wide choice of formats.
    If the plasma supports HD, is it worth using an HD format (material will be largely animated graphics and still photos I think)? Or does the relatively large distance people will typically be viewing from mean that upscaled DVD-quality would look as good ..?
    If HD, any thoughts on 1080p vs 720p, choice between QT and wmv – or other formats ..?
    Rich Rubasch replied 19 years ago 2 Members · 1 Reply
  • Rich Rubasch
    September 11, 2007 at 1:50 am
    If it’s a Mac laptop I would go with progressive 30p H.264. You also don’t specify how you will edit the material…is it on a Mac or a PC? More info on your workflow might help us make a stronger suggestion.
    Rich Rubasch
    Tilt Media
