Activity Forums Adobe Illustrator Preferences not responding. Incredibly frustrating
  • Preferences not responding. Incredibly frustrating
    Posted by Ryan Paterson on April 5, 2012 at 7:45 pm
    I’m having a hair-pulling problem with Illustrator that seems to defy logic. 2 things-
    1) My ‘keyboard increment’ preference is simply not responding to values lower than 1pt. If I go over 1pt it’s fine, but if I set it to say ‘.01pt’ it will just keep incrementing by 1pt. I’ve tried turning off all of the “snap to” settings, I reset the preferences, I even tried deleting the preferences file- nothing works.
    2) There seems to be a minimum distance I need to drag things before they will actually move. For instance if I drag an object only a few pixels it will snap back into it’s old spot.
    Can someone please tell me WHY?!?! So frustrating… I’m going to try re-installing now. Thanks in advance for your help!
    Tylor Larson replied 14 years, 4 months ago 2 Members · 3 Replies
  • Tylor Larson
    April 9, 2012 at 9:28 pm
    not sure if this will solve your problem completely… but you could reset your illustrator preference file. Some times Preference files get corrupt. i just set my keyboard increments to 0.0139 and check it against a box that was 0.0139×0.0139 and it lined up when i moved it.. i really think trashing your prefs should help.. also make sure smart guides and all snapping is off… which i understand you have checked… but if you trash your prefs and restart illustrator snapping will be back on by default.
    link below for trashing prefs..
    https://www.illustratorhints.com/2010/05/delete-preferences-file/
    Good luck… please let me know if this works for you.
  • Ryan Paterson
    April 9, 2012 at 10:03 pm
    Ya as I mentioned I had already tried that. I re-installed Illustrator and it fixed the problem so, not really sure what the heck was wrong there but it’s all fixed up. Thanks anyway!
  • Tylor Larson
    April 10, 2012 at 4:57 pm
    Ryan,
    some times a system can have multiple pref files for a single application. Like if you upgrade from cs1 to cs3. Maya does that a lot when you upgrade it. i can’t remember if adobes stuff does or not. sorry you had to re-install… that is really annoying. best of luck
    TY
