Activity › Forums › Apple Final Cut Pro › Preferences
Preferences
Posted by Simon Chan on November 9, 2011 at 12:40 amPreferences? Where are they located? Am I blind? I can’t find them.
Simon Chan replied 14 years, 10 months ago 3 Members · 7 Replies -
Loren Risker
November 9, 2011 at 12:44 amDo you mean besides the preferences in the normal spot under the Final Cut Pro menu at the top?
Or are you referring to project settings? You can access those by selecting your project in the project pane and your properties will pop up in the inspector window. From there you can click the wrench button for more options.
Simon Chan
November 9, 2011 at 12:47 ami mean application preference file so i can delete it to reset the fcpx.
Loren Risker
November 9, 2011 at 12:47 amOh whoops, just saw your “in Lion” post.
They’re located here:
/Users/username/Library/Preferences
However, accessing it from the Finder is a little more difficult since Lion makes the users Library an invisible folder. I think the easiest way to access it is to use the go to folder command in the finder.
Simon Chan
November 9, 2011 at 1:00 amah i see. but yeah it’s invisible. and i tried go to folder command and it didn’t find it.
Tom Wolsky
November 9, 2011 at 1:26 amHold the Option key and the Library will appear in the Go menu.
Use Preference Manager from Digital Rebellion.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
Coming in 2011 “Complete Training for FCPX” from Class on Demand
“Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press
