Activity Forums Adobe InDesign Predefined Row height, Top cell insert, and Bottom cell insert
  • Predefined Row height, Top cell insert, and Bottom cell insert
    Posted by Rick Towle on December 18, 2019 at 11:31 pm
    I need some help. I am using InDesign CS6.
    I have spreadsheets that I create and import into InDesign.
    After I import each spreadsheet into InDesign, I have to highlight the entire spreadsheet and change the following settings; Row height, Top cell insert, and Bottom cell insert.
    Doing this is a pain in the butt when you are constantly doing edits in you excel spreadsheet and then updating them in InDesign each time. Then I have to do the procedures that I previously mentioned.
    Is there way to create a script that I can run on my spreadsheets to do all of these changes within InDesign? Or is there a way to make my spreadsheets that are imported into InDesign default to the same predefined Row height, Top cell insert, and Bottom cell insert each time they are paced inside my InDesign document.
    Rick Towle replied 6 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
