Precomps and the playhead
Firstly sorry if this is a dumb question,
I’ve a large composition that contains several precomps.
When I move between main composition and precomps the playhead does not ‘land’ in the same positon. For instance if in the main comp the playhead is a 4:00:00 and I jump to a precomp the playhead is now at 4:00:10. Its only when I select the precomp and right click open compostion that the playhead is positioned correctly. However when I go back to the main comp the playhead has changed position again.
It was working fine and landing correctly until an hour ago and now it’s all over the place…
I know this must be so simple a problem but I’m just stuck.
Thanks for help.
