Activity Forums Adobe After Effects Precomposing moves 3D layers out of sync?
  • Precomposing moves 3D layers out of sync?
    Posted by Shirak Agresta on February 16, 2008 at 8:53 pm
    Okay, new issue:
    I’ve got some graphics moving along a motion path via Dan Ebbert’s “trails” scripts, the ones for position and orientation. I’ve got a 3D camera doing a simple pull back move.
    Okay, now when I try to precompose all the layers (graphics, camera, and null with sliders that control graphics) into a new comp with the EXACT SAME SETTINGS, the camera position and timing of the animation is off. Everything seems to shift over, starts later, etc. I’ve double checked between non and precomposed layers and all the settings seem to be exactly the same. I’ve also tried creating a new, blank comp and dragging the comp with the layers into it and the same thing. Argh.
    I’ve checked the expression scripts and they don’t seem to be the issue as they’re not comp-named dependent. I’m mostly precomposing to keep my main comp tidy, but it’s really, really frustrating. Any ideas?!
    Thanks…
    Julius Caesar and the Roman Empire couldn’t conquer the blue sky.
    Shirak Agresta replied 18 years, 6 months ago 20,646 Members · 2 Replies
  • Shirak Agresta
    February 18, 2008 at 7:13 pm
    Thanks. The timing issue may just be an illusion created by the shifting of position. So how could I fix this if I need the anchor point of one of the layers to be shifted? Do I change the anchor point of the new precomp to that of the other anchor point position?
    Thanks again!
  • Shirak Agresta
    February 19, 2008 at 9:15 am
    Great, thanks so much for your help! That explains a lot.
