Activity Forums Adobe After Effects Precomposing Adjustment Layers?
  • Precomposing Adjustment Layers?
    Posted by Lawson Deming on June 25, 2008 at 6:45 am
    I’m doing beauty work on a music video that requires a number of masked adjustment layers applied to each shot (grain reduction, selective color correction, etc.) There are around 50+ shots that all need the same work done on them – the only difference between the shots is that the masks for each adjustment layer have to be keyframed differently because the artist is moving around differently in each shot.
    Each shot is its own composition right now – its no problem for me to simply copy the adjustment layers from one comp to another and re-keyframe the masks, but there is a potential problem if any of the effects end up getting changed…
    If, for example, the director decides to tweak the eye color again after I’ve done work on all 50+ clips, I have to go back into every single composition and change eye color adjustment layer values – I’m making the exact same change 50+ times. Then if he changes his mind and wants to go back, its the same thing all over again. Instead of wasting time doing this, I’d like to be able to change the value once and have it affect everything.
    It seems to me that there should be some way to make a separate Precomp for each of the adjustment layers and then link to those precomps in every shot composition. Then, if I need to change the eye color by five points or change the grain reduction to make it a little bit softer, I just go into the appropriate precomp and change the adjustment layer and ‘bam’ – it applies that change to every shot comp that references that precomp.
    Obviously, the problem with this idea is that precomps are specifically designed to keep the adjustment layers within them confined to the precomp. They don’t carry over to the compositions that reference them. That’s often the point of precomposing something. So, if I were to create a precomp that contained only an adjustment layer and I called on that precomp from one of my shot layers, I’d essentially be bringing in an empty layer.
    Is there any way to create an adjustment layer that can do what I need it to do? Each adjustment layer is exactly the same in every shot – I want to change it once and have it apply to everything. I could simply dump all the shots into one comp and lay a single adjustment layer over all of them, but then the problem is that I’m stuck trying to manage a huge timeline and I also need to create tons of tracking layers and mask keyframes. I’d rather keep each shot as its own composition so that everything is clean and manageable.
    Any suggestions? Am I going about this the wrong way?
    Robyn Rhodes replied 18 years, 2 months ago 2 Members · 1 Reply
  • Robyn Rhodes
    June 25, 2008 at 1:38 pm
    I’m not expression wizard, But I think you can do it by linking the color parameter to a expression slider. Hopefully this makes sense.
    r
    I’m only half the thing I say I am, the other half are me.
