Activity › Forums › Adobe After Effects Expressions › Precomp source text based on main comp time
  • Precomp source text based on main comp time
    Posted by Kristine Jones on July 28, 2022 at 5:28 pm
    I’ve created a one hour countdown timer. At the start of each minute I’d like to transition to a different background for 5 seconds then transition out. This new background requires a change in the timer’s text color.
    To achieve this I’ve created a precomp with the new background and a duplicate of the timer text layers with text recolored. Ideally I’d like to reuse this single comp multiple times on top of the main timer, instead of creating a new precomp for each minute’s change.
    Within the precomp I’ve changed the source text expression to: comp(“countdown”).layer(“00”).text.sourceText;
    This gives me the text I want to see, but from the beginning of the main countdown comp. If my precomp is located at X min on the main comp’s timeline, what code would I add to display the text at that point in time?
    Kristine Jones replied 4 years, 2 months ago 2 Members · 2 Replies
  • Dan Ebberts
    July 28, 2022 at 5:51 pm
    Try this:
    c = comp("countdown");
    c.layer("00").text.sourceText.valueAtTime(time + c.layer(thisComp.name).startTime)
  • Kristine Jones
    July 28, 2022 at 6:00 pm
    Perfect. Thank you, Dan!
