Activity Forums Adobe After Effects Precomp into a folder?
  • Precomp into a folder?
    Posted by David Del on May 1, 2009 at 12:16 am
    Is there a way to move pre-comps on the timeline (tabs) into a folder so I don’t have to scroll through all of them to get to the main comp? I am not talking about the project window (which has folders), but the actual timeline for the comp which also has the series of tabs on top to represent all of the precomp into the project?
    David Del replied 17 years, 4 months ago 2 Members · 2 Replies
  • Dino Muhic
    May 1, 2009 at 2:23 am
    There is no such option, although I really would like to have it too 😉
    But you can either put all the precomps you want to have in a folder in a second pre-comp and turn on the continuous rasterization (a pre-comp IS a folder if you look at it that way) or you could turn on the shy layer switch and just make them invisible for the time you need.
    Dino Muhic – Media Producer
    VFX – Motion Graphics – Web-Design – Or just ART
    http://www.dinomuhic.com
  • David Del
    May 1, 2009 at 2:29 am
    thank you for that.
