Activity › Forums › Apple Final Cut Pro › Precision editing (sub-frame editing)
Posted by Adam Chesbrough on May 21, 2013 at 11:11 pmI could be wrong but I feel as though my edits were just much sharper with FCP7 then with FCPX. Sometimes I can simply not cut to the beat because I am unable to move the edit point exactly where I want to. I don’t remember this ever being a problem.
Please see the attached screenshots. I want the edit point to be on the marker…FCPX says NOPE! Any thoughts? Are there editing systems out there that allow for sub 1 frame cuts (I have turned off snap and magnetic by the way to see if that solved it…it did not)
Macbook Pro Retina: 2.6GHZ i7, 16GB RAM 1600MHz DDR3, GT 650M 1GB RAM
Hackintosh (Sandy Bridge): i5 2500, 16GB 1333MHz DDR3, Nvidia GT640 2GB RAM
OWC 4TB RAID0 (using esata)
Tempo SATA Pro ExpressCard/34 (6Gb/s)
Echo ExpressCard Pro Thunderbolt AdapterTim Dutton replied 8 years, 6 months ago 6 Members · 6 Replies -
Charlie Austin
May 21, 2013 at 11:18 pm[adam chesbrough] “Are there editing systems out there that allow for sub 1 frame cuts”
Nope, at least not for video. For audio, yes. In fact, X is way more flexible than 7 and other NLE’s when cutting audio only. Video, on the other hand, must be cut on a frame boundary. X will allow you to put an audio marker at a subframe location, FCP 7 will not. That’s probably what you’re noticing…
~”It is a poor craftsman who blames his tools.”~
~”The function you just attempted is not yet implemented”~ -
Jeremy Garchow
May 22, 2013 at 12:46 amYou can move the marker to the cut by nudging the audio in subframes.
Fcpx follows video frame rates (it has to) but audio can be adjusted down to 1/80th of a frame.
Ryan Patch
May 22, 2013 at 5:05 amThere is no possible way to edit in an increment smaller than a frame. A video will run at a fixed FPS (23,98, 24, 19.97, etc) and to try to make a half-frame duration would throw everything out of whack. There isn’t and has never been a video editing system that will allow you to edit “sub-frames”.
This was the case in FCP7. You could only edit as detailed as a frame. There may be other reasons that FCX might be preventing you from editing the best you can, but this is not one of them.
You CAN, using Premiere, FCX, and Avid, edit AUDIO at the sub-frame level. I know in Premiere you can make edits up to the precision of the sample rate (usually 1/48,000th sec).
I would say that, in my opinion, even if an audio hit is 1/2 frame “off” (the most it ever would be) you don’t notice the .05 second difference. If it’s really that important to you, you can slip the audio in subframes.
R
Jacob Brown
May 23, 2013 at 12:08 amanother good way to align the visual frames to audio subframes is by retiming slightly.
use the range selector. select a range that encompasses the audio marker and visual marker. shift-n. you will now be able to adjust the timing of that range and fcpx will automatically ramp up/down.
Adam Chesbrough
May 23, 2013 at 3:55 amgood thinking, will give that a go. Thanks
Echo ExpressCard Pro Thunderbolt Adapter -
Tim Dutton
March 7, 2018 at 10:34 pmIn my opinion retiming isn’t necessarily the best solution. It may work kind of in some situations.
I do a lot of audio mixing for music video. This consists of multiple camera angles shot over multiple takes where the artists perform the music in sync to playback audio that they sing along to. On each take the playback audio may start at a different point within the video frame so that, for example, if there is a click at the top of the song to bring the performers in, on take one the click may be at the beginning of a video frame, on take 2 it may be .5 frames later within a frame, take 3 may be .25 frames later within 1 video frame. When you line up the video and audio in post, you can see that the best alignment you can get for that first click is +/- .5 frame of video so it’s likely that video from each separate take is a quarter to half a frame out of sync. I have noticed that to get the best looking result even a quarter frame matters. You can start to subtly notice something “wrong” when picture and audio are as little as .25 frames off. I will mix audio in Logic Pro and I will often shift audio by one, two, or 3 quarter frames until it just looks more “real”. Also, I am often using live tracked audio so I know the audio is what the singer sang when that video camera was recording – not sync imperfections by the artist.
I haven’t tried this yet, but I have an idea. Maybe more experienced editors could chime in here. What if you tried making your sequence/timeline settings be double or even quadruple the frame rate that your source footage is at. So, for example, if your source footage is 29.97, double it to 59.94. Then, couldn’t you edit with .5 frame accuracy (compared to your source footage)?
Would this be practical/a good solution? Like I say, I haven’t tried it yet, but I have thought a lot about this problem. To completely solve it, either the original playback audio has to be synchronized to video frames WITHOUT synchronizing to the SMPTE TIME position (cameras are running SMPTE on time of day timecode, audio playback is not) OR trying my (untried) idea of making smaller frames in the timeline to edit at subframe accuracy.
Please, someone smarter than me tell us if this is a good idea, or why this won’t work. What do you think?
