Activity › Forums › Adobe After Effects › Precises metaballs animation
  • Precises metaballs animation
    Posted by Filip Cerny on November 15, 2021 at 1:24 pm
    Hey there, I have a shape like the one attached – basically, several circles connected like metaballs. I would like to animate these circles around so the connections form and break apart and end up in this particular shape. However, whatever AE technique for metaballs I use usually ends up looking different (the circles won’t connect in this distance etc.). Is there a particular method that you would recommend that gives a high level of control so I can get exactly what I want pixel perfect? Thank you very much!
    Filip Cerny replied 4 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
