Activity Forums Adobe After Effects pre rendering in after effects
  • pre rendering in after effects
    Posted by Mathew Lisett on June 1, 2010 at 12:15 am
    hi guys, im trying to understand something.
    with the pre render, am i correct in thinking this simply renders the footage and replaces the new footage into the prject. so that you are then workign with the new footage and can then correctly apply other filters without looking a mess?
    Todd Kopriva replied 16 years, 3 months ago 2 Members · 1 Reply
  • Todd Kopriva
    June 1, 2010 at 11:28 am
    Yes, pre-rendering takes a nested composition, renders it, and replaces the nested composition in a composition with the rendered movie.
    The value of pre-rendering is that you render an item once rather than forcing After Effects to render and re-render it every time that the item is used.
    from the Help document:
    “A complex nested composition can take a long time to render, either for previews or for final output. If you have a nested composition that you do not expect to work on further, you can save time during each rendering operation by pre-rendering the nested composition into a movie and replacing the composition with the rendered movie. You can still modify the original nested composition, because it remains in the Project panel. If you make a significant change to the original nested composition, just render it again. Pre-rendering a nested composition is especially beneficial when you will use it multiple times in a project.”
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
